Clicking Noise Underneath Center Console
So I'm having an issue with my Trans Am. It's a 2000 TA M6. I don't drive it very often anymore, but when I do I get this awful noise every once in a while from underneath the center console. It sounds like the ABS is going off or something and it is usually only triggered when driving over bumps or uneven surfaces. I've looked underneath for anything loose that might be making a noise but I haven't found a culprit.
The sound increases or decreases along with the movement of the vehicle and once it starts it usually continues. One of the first times it ever happened it seemed like my car wouldn't move, like stuck brakes. I put it in reverse and it unlocked and the noise disappeared for a few days. Of course it started back up again. It's fairly intermittent but not subtle by any means.
Any ideas?
Any ideas?
Save the manuals!
Are the outer circumference of your current tires the same as stock? If not, that could be exaggerating your problem.
When the tires are different, then the ABS sensor reports will be off from what the computer expects compared to the car's speed. From what most people experience when changing tire sizes, there is some tolerance in the ABS/TCS computer for the sizing to be off. However, if a sensor is starting to go out, it will be much more sensitive if the tire sizing has pushed the wheel speed further off spec.
^ If a wheel speed sensor is going bad, hopefully there is an ABS code to provide some hints as to where the issue might be.
