A/C question
Old 09-21-2017, 04:51 PM
beedo's Avatar
Default A/C question
Need a little advice on my AC, compressor is not kicking on so I jumped the relay. Compressor comes on with the relay jumped and the low side pressure is ~45 and I am getting cold air from the vents. I am thinking the High side pressure switch but dont want to throw parts at it and was hoping someone new how to check it. Trying to get a scanner to see if the PCM is commanding the compressor on but with the relay jumped the high speed fans come on as well. Any help would be appreciated
Old 09-23-2017, 04:44 PM
01ssreda4's Avatar
I believe you can just pull the connector off and jump the terminals.
Quick Reply: A/C question
