WS6 making a rattling noise when it's in Drive , But ........
WS6 making a rattling noise when it's in Drive , But it stops rattling as soon as I put it in Neutral
For some reason , my WS6 ( Only when i am at a stoplight ...... when the car is in Drive and I have my foot on the brake ) , it starts making a Rattling / chugging type sound ( in a way , it sounds a bit like it has a Cam on it , but it doesn't
As soon as I put the car in Neutral ( when at a stoplight for example and I have my foot on the brake ) ........ When I do this , the rattling / chug type sound immediately quits
Can someone please help with diagnosing what this sound could be coming from
Also:
the sound ( rattle / chug noise ) gets louder if I have the AC on , but again , when i put the car in Neutral ( even with the AC running ) the sound quits
Thank so much for the help
Also:
Hi wssix99 ,
Thank you for replying
Yeah , as soon as i give it gas and start to move , it instantly goes away
Same thing with when I am stopped ( at say a red light ) and I put the car in Neutral ........ It immediately goes away
Only when the car is running / is in Drive / I have my foot on the brake , does it make that Rattling type sound
Thank you again for your time and your help
wssix99 ,
Thank you for diagnosing the problem for me
It has been making this noise for 4+ years now , and the Transmission still seems strong
What is an Average cost to have the Torque convertrr replaced ?
And would you recommend I look at having anything else replaced/looked at , to help avoid more costly repairs down the road ( trying to keep my Transmission from going out )
Save the manuals!
This is a normal part that wears out. It takes the place of a clutch on a manual transmission car.
Nothing to worry about here.
How many miles do you have on the car? Are you over 150K?
As far as cost, etc. you might post in the Automatic Transmission section. Folks there will know more about these things and can give you some good advice as to how to go about it. (My advice is going to be to rip out your transmission and convert the car to a manual!)
Save the manuals!
I recall that the T56 transmissions are REALLY hard to come by these days in good condition.
You should be able to get the Torque Converter replaced for way under $1000. The most expensive part should be the labor because the transmission needs to be dropped to get to the part.
