Oil Pump single bolt to tube Size.
It's M6-1.0X20, but you really don't want to get a regular bolt - the OEM bolt has maybe 3/16" at the end which is narrower with no threads, and that makes it much easier to get the bolt inserted when you're working with a dropped oil pan and no room, trying to use a regular bolt is much harder.
