Traction Control Indicator Lights Not Working. Please help trouble shoot.
I have a odd problem. My traction control works just fine but both the TCS ON/OFF light and LOW TRAC indicator light in the gauge cluster do not work. Neither does the indicator light on the traction control switch itself.
Clicking the switch does turn traction control on and off as I can easily test it and feel it working on the gas pedal, but all lights and indicators associated with the system do not work.
Any idea how to start diagnosing this issue? I checked all fuses associated with traction control and gauge cluster and all are fine.
I also tried grounding the brown/white wire on the traction control switch and it failed to light the switch indicator on.
Appreciate any advice to help solve this. Thanks.
Ungrounded Moderator
The ON indicator light in the switch is on the circuit protected by the GAUGES fuse. You could check that fuse but I would expect other symptoms beyond just TCS if it was blown (daytime running lights, rear hatch release, etc.).
The instrument panel indicators are managed by serial data rather than a simple power/ground switched circuit. That makes it unlikely to be a fuse or single wire causing the problem. Do the indicator lights come on during the bulb test when starting the car?
The TCS indicator light switch never turns on but as I mentioned the switch does work.
When the car engages traction control and pushes back on the accelerator, the LOW TRAC light does not turn on as it should to indicate its active.
