Which oil filler neck for 799 valve covers
Old 12-29-2017, 10:23 AM
jaxcam02's Avatar
Default Which oil filler neck for 799 valve covers
I'm in the middle of can head swap. The valve covers off the 799 heads will not accept the oil filler neck (dorman 917-413). Also my oil cap from the old 241 heads don't fit the new neck. So I tried to find the difference between the two different valve covers. It seems the ls1 cover has one notch at the 12 o'clock position to accept the oil filler. The 799 covers have two notches.
799 valve cover. Notice to two notches at 3 and 9 oclock positions
Anyone shed some light on this?
Old 12-30-2017, 12:03 PM
BALLSS's Avatar
would just trimming off one tab on the VC work?
or is this the right one
https://www.ebay.com/itm/10-14-LS3-L...-/121756642087
Old 12-30-2017, 02:18 PM
jaxcam02's Avatar
Quick look at it it looks like that's it. Thank you.
Old 04-10-2018, 10:50 AM
jaxcam02's Avatar
update:
GM Oil Fill Tube 12609623 is the two tab PN
Old 04-14-2018, 10:49 AM
LS1121's Avatar
How about this one?
https://www.ebay.com/itm/GM-Filler-T...FZ3n0e&vxp=mtr
Old 04-16-2018, 08:36 PM
Crf450r420's Avatar
No, that is a single. You can just put the cap on the cover. Use the number listed above, 12609623.
Quick Reply: Which oil filler neck for 799 valve covers
