Anybody have clue what's wrong?
I have a stock 02 Camaro SS, weekend cruiser. Pulled it out the garage and everything was running fine. Tried to crank it later and it ran for about 10 seconds then stumbled over and died. Tried to restart but this time gave it a little gas and it died immediately when i pressed the gas pedal. Anybody ever experience this issue or have a clue what might be wrong?
Any DTC codes? Bad gas? Clogged fuel filter? Will it start with a little starting fluid into the air filter hole? Don't use a lot of this but it is a good diagnostic tool.
Rick
Rick
I was thinking the same thing. I gonna get fuel pressure gauge and start with that. Then check filter and injectors. I really hope it isn't the pump because I don't have the trap door mod. Any recommendations on an aftermarket replacement fuel pump?
LS1Tech Administrator
Received 1,471 Likes
I agree with checking fuel pressure and for any stored codes to start. I wouldn't worry about replacing anything until you have some idea of what's wrong based on those diagnostics. If it does need a pump, and you plan to keep the car stock/stockish, I'd go with a Delphi replacement (they were the OE supplier).
