Sponsored by: CARiD
Is this a problem?
Old Apr 5, 2018 | 01:15 AM
LS_Power's Avatar
Default Is this a problem?
so a few weeks ago I got heads, intake, and upgraded injectors installed on my car. Now I’m having this problem where if the car is already warmed a little and sits outside for like 20 minutes and I go to start it again it’ll start up then die right away then when I try turning it on again it’ll take awhile to turn over then it’ll run fine. Anyone know what it could be and if I should be worried about it?
Old Apr 5, 2018 | 09:20 AM
jaxcam02's Avatar
try turning the key on an off a few times to prime the fuel system. Listen for the pump to turn on. then try to start the car after priming and see if you notice a change.
Old Apr 5, 2018 | 10:56 AM
LS_Power's Avatar
I will give that a try next time
