How to Disconnect Fuel Pump Relay
I have the DS kicker panel removed (mine had the 5 stock holes but only four screws —> missing one on the foot rest area). I suppose ACE Hawrdware would have that fifth screw if I desired to go get one?
i havethe interior flooring (carpet) pulled back but I have some of fattest hands I can’t get in there to press the snap connector hook so I can pull the relay off. Being 5’6 1/2 and 200lbs makes this a pain in the ***.
ive read shoe box website and it looks like he just pulled the connector off the metal brace that goes behind the foot pad? Either that or the clip that holds the connector just can be slid off? Then disconnect the relay? I’ve been trying to work with getting the relay off while the connector and unit is still attached to the metal food rest brace.
thanks in advance for the help!!
