OK speedo problem.... i have tried all i know.
99 ls1 camaro
i have my 5th cluster in here...all 99 and up fbody camaro or ta clusters.
so hp tuners will show a slight signal often to 40mph with a helluva delay. cluster may burp up to 15 mph every now and then even if im doing 100mph
so far.
1. i have replaced the speed sesnor
2. replaced the cluster (several times)
3. tach and orher gauges work. oil pressure and fu doesnt work on some of the clusters.
any suggestions to check or try?
so far.
99 ls1 camaro
so far.
so far.
I dont have a lot of light or room. Can someone tell me where does the VSS wires come into the car? I know it has to be by the shiftier somewhere. From the PCM pins 20 and 21 are light green/black and purple/white.
From the cluster I think they are yellow and purple (not 100 percent sure here) 99 and up PCM
If I wanted to access these wires from inside the car can someone give some insight on where to look? If I pull up my console panel will I be able to access them?
Thanks in advance!
Thanks in advance!
