Door Hinge Roller Replacement
Old Jun 22, 2019 | 09:14 AM
Bill00Formula's Avatar
Default Door Hinge Roller Replacement
I've taken the hinge off and removed the roller. I am trying to remove the pin. What a pain.
I saw a great youtube video from Matt that made it look easy. Wish I could contact him. He's not very far from me.
Any suggestions?
Thanks
Old Jun 22, 2019 | 12:47 PM
bsf's Avatar
bsf
Are you referring to the small pin which retains the check roller to the larger pin; or the larger pin which actually goes through the hinges?
I serviced the driver hinge assembly last fall on my S10; including the entire detent / check roller sub-assembly. I just bought all new parts. I have no desire to ever attempt removing the small pin for the check roller.
ETA
On the S10, removal is a destructive process, so there really is no choice but total replacement.
Old Jun 22, 2019 | 08:06 PM
wannafbody's Avatar
I think if you cut the pin and then drive it out it's easier.
Old Jun 22, 2019 | 08:08 PM
bsf's Avatar
bsf
I agree. That is what I did.
Old Jun 23, 2019 | 08:23 AM
wssix99's Avatar
Save the manuals!
Do you have a link to the video?
Old Jun 23, 2019 | 09:53 AM
Here is the video that I was referring to.
I ended up bringing the hinge to a repair shop. I sent them the video for reference.
Old Jul 21, 2019 | 10:12 PM
wssix99's Avatar
Save the manuals!
Added to the sticky!
This looks like a perfect job for a slide hammer. If I were to do this, I would use the slide hammer (with vice grip attachment) for removing that pin.
(This is the perfect once-in-a-long-while type of tool to get from Harbor Freight for a low investment.)
Old Feb 8, 2022 | 01:39 PM
98_NBM_TA's Avatar
Bringing this back from the dead. I've tried following the process in this video but I cannot get the pin out. I've tried heating the hinge with a torch and using a punch and hammer but it's just beating up the hinge. It's like the pin is welded in. Anyone have any other suggestions?
Old Mar 2, 2022 | 04:47 PM
2ToeRacing's Avatar
Does anyome make a aftermarket replacement?
Old Mar 3, 2022 | 08:27 PM
wssix99's Avatar
Save the manuals!
Hinge or a replacement roller?
Old Mar 3, 2022 | 09:00 PM
wannafbody's Avatar
Dorman makes replacement hinges. I'm not sure about the roller.
Old Mar 12, 2022 | 07:58 AM
MMBM's Avatar
https://www.hawksmotorsports.com/82-...r-bushing-pin/
Cheap enough👍
Old Mar 12, 2022 | 08:05 AM
MMBM's Avatar
https://www.hawksmotorsports.com/199...ge-repair-kit/
Very expensive, but so sweet, saving my pennies for these!👍
Edit: Sorry for all the deletions and edits, didn't realize I was posting 3rd gen stuff initially!
Old Mar 13, 2022 | 03:42 PM
wssix99's Avatar
Save the manuals!
I put these in and regreted it. I would have preferred the non-greasable ones. The non-greasable busings are a huge upgrade and its impossible to get a standard grease gun on these fittings once the hinge is reinstalled. (So you probably won't be aplying much grease.)
