2000 FBody Charging Issues - Plz Help
Symptoms:
Battery voltage reading car off: 12.67
Battery voltage reading car on, no load (lights off, radio off, fan off): 12.01
I didn't even bother putting a load on the battery as you can see the alternator is not charging well enough.
Attempted Fixes/Diagnosis:
Alt was purchased on June 1 of this year brand new, it is the alt from a 2000 Chevy S10 with the V6. I took it back to the parts store to have them test it (off the car) and it passed with flying colors, 14.92 voltage output. Not the alternator
Battery was purchased from same store 2 days prior, the previous alt killed the battery and it was beyond saving so a new battery was needed before determining the alt also needed replacing. The battery holds a charge of 12.67 overnight with no issues. Battery not the problem.
Checking for a short was the next thing I found on the forums. So i got my multi meter and also purchased a 12 volt test light.
At first, the test light showed a short was present. I pulled each and every fuse and relay from the dashboard side panel, then from the inner most fuse box under the hood, then finally the second fuse box under the hood. I was unable to get the light to shut off. I also disconnected the stereo equipment in the trunk, but with no changes.
I then hooked up the multi-meter and found there was no amp draw, (0.01). I replaced each relay first, checking for an increase in draw each time. Then replaced each fuse. I was unable to get an amp draw above 0.04, which seems pretty standard for "everything is ok". I then hooked up the test light again, this time, the light did not come on leading me to believe that no short exists. With that, I started the car up and checked the voltage on the battery. It was still 12.01, not nearly enough to maintain a charge.
So now what? Is there a wiring issue under the hood? Could the harness itself be bad? I am starting to think that this might not be something I can diagnose and fix myself :/
Anything helps. Thanks.
As far as the grounds are concerned, they might be the issue. The hot wire that runs to the post on the back of the alt is on fire, melting its way through plastic conduit and also starting in on the alternator shield itself.
This wire getting unnecessarily hot makes me think that something is getting grounded when it shouldn't, which is what lead me to look for a short, which I was unable to find. Could any of the grounds cause this? I don't know why this would start happening all of the sudden if it was a ground wire, but I am definitely up for doing some investigating.
Maybe this is too obvious, but was the melted wire touching anything that it shouldn't have been? Perhaps a small bit of missing insulation has resulted in a self-worsening problem.
But then, the suggestion about checking grounds is a good one as well. Looking at the engine bay picture above I can see several non-stock items, so the car is obviously modified. How much of the engine/engine bay has been taken apart at some point? Perhaps some key grounding points have been marginal for quite some time, and general corrosion/operational vibration has finally taken them from marginal to unacceptable.
What was the very first symptom? Just poor charging? Or did something else occur (or was some other work done) immediately prior to whatever alerted you to the fact there was a problem?
I don't necessarily trust the alternator test machines at local parts stores. I've gotten several false "good" readings before, only to have the alternator fail to charge once it's fully heated up during normal operation. But it sounds like your charging issue begins from the moment the engine is started, even cold, so this is probably not your issue - not to mention the melted wire.
The behavior of the test light is odd. Do you happen to have another one you can use to verify? I don't know why it would continue to indicate a problem with everything disconnected, but then stop indicating a problem once everything is reconnected.
The center console comes out when the trans is removed, so I can open that up and check for randomly grounded wires. I will definitely be replacing the output wire today. Hoping the output wire was the original issue and maybe then the issue just goes away.
Thoughts guys?
Have you checked continuity and voltage on Terminal F and Terminal L at the alternator?
Rick
Rick
it’s actually 14.6 with no load. Once everything is on and running it comes down to 14.2. I don’t have AC but I have electrical radiator fans. I have not been able to check continuity from F and L terminal. I was also going to try and check the current on the alt while it’s running.
Doubt it will give me any trouble anymore tho
Everything is running great! Using the alt from a 2000 S10 with the V6 (fitment reasons) and charging issues have disappeared once that wire was replaced and upgraded. Thanks for your help all
