Ls1 overheating
I’ve got a 2000 gu patrol with an ls1 turbo
i built the Ute a few years back been fixing little things up here and there it was running great for a year or so. Coolent got low one day so I topped it up and after that it kept getting hot I done a co2 test and it come back positive
I removed the heads couldn’t really see where the head gasket had blown
I also found bearings and rings were stuffed from low oil pressure so I replaced all bearings, rings lifters etc
checked block and heads too see if they were warped with a straight edge everything looked okay
Fitted new head gaskets new bolts and torqued correctly
also changed the radiator and water pump with a thermostat
started it today but is still getting hot after a few hours of trying to bleed the cooling system
I done a co2 test again and it was positive again
what should I check now
I was going to separate the turbo cooling side incase it’s leaking computation into the cooling side of the turbo
any help or suggestions would be much appreciated
