LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   General Maintenance & Repairs (https://ls1tech.com/forums/general-maintenance-repairs-102/)
-   -   Still Won't start (https://ls1tech.com/forums/general-maintenance-repairs/225346-still-wont-start.html)
Slow TA Oct 9, 2004 12:48 PM
Still Won't start
replaced the starter and solenoid checked the crank fuse, checked lock and key switch. the battery and connections are good also. and its not vats.
when I try to start the car nothing happens. all my lights work and radio and everything it just won't start. it won't click or anything. I need help and I don't wanna take it to chevy.
1BadpurpleLT1 Oct 9, 2004 12:50 PM
Try taking the battery cables off and cleaning them, then try it again.
Slow TA Oct 9, 2004 12:51 PM
ive tried and it still won't click or anything.
Camaroz Oct 9, 2004 01:00 PM
how do the cables to your starter look?
if theres no power to the starter take a electrical tester and find the point where you arent getting power
Slow TA Oct 9, 2004 01:02 PM
they are good too the big wire is getting 12 volts like it should but the small wire gets nothing when I try to start it. when I try to crank it it should be getting 12 volts also.
Camaroz Oct 9, 2004 01:04 PM
edited post wow your quick ;)
what small wire are you talking about? got a pic?
Camaroz Oct 9, 2004 01:38 PM
alright sent you a PM but incase you didnt get it....
the small wire would be the neutral safety switch correct?
the neutral safety switch may be out of adjusement.. its under the housing near the shift lever
Slow TA Oct 9, 2004 01:58 PM
I don't know if it is our not. its purple though. I did'nt check the saftey switch is that on 6 speed cars?
Camaroz Oct 9, 2004 02:09 PM
no then you would have a clutch interlock that prevents you from starting the car without the clutch engaged fully look around your clutch pedal and see if you can find it i think there is 2 switches the interlock switch would be the one with the long plastic tube looking thing you can bypass it to test but i wouldnt recommend keeping it bypassed if thats the problem since you could run over someone when trying to crank the car if you forget to depress the clutch
i should have asked if it was a stick or automatic my bad :bang:
Slow TA Oct 10, 2004 07:02 AM
alright ill give it a try today.
z28s Oct 10, 2004 08:22 AM
do you have an aftermarket alarm with starter disable? i've seen 2 cars where the starter disable function stopped working, something went wrong with the brain.
Slow TA Oct 10, 2004 08:33 AM
no I don't have any kind of alarm on it
Slow TA Oct 10, 2004 08:48 AM
I checked the lock and key but what about the ignition switch. do these cars have them because I did'nt see it when I took off the steering wheel. That may be a stupid question ,but on my friends truck the ignition switch was right there by the lock and key switch
97LT1 Oct 11, 2004 12:37 AM
No its way in the depths of the lower dash.
LFNDUST Oct 11, 2004 12:44 AM
is the car getting spark? or when you turn the key it does nothing...?if thats the case ignition...
Slow TA Oct 11, 2004 07:06 AM
alright taking apart the steering wheel again. I mine as well replace the ignition while im down there see if that works. already replaced everything else.
Slow TA Oct 11, 2004 07:14 PM
Does anybody know where the ignition switch would be on a 95 trans am?
TonyJ Oct 12, 2004 09:20 AM
Check out this great page by shoebox...
http://shbox.com/ignsw/ign_switch_repl.html
Slow TA Oct 12, 2004 05:56 PM
thanks you just made things a whole lot easier.
Camaroz Oct 12, 2004 06:06 PM
seriously that would be tough to tackle without that tutorial good luck man tell us your outcome :)
© 2026 MH Sub I, LLC dba Internet Brands
