Tachometer acts wacky!!! WTF?
My tachometer works perfect when slightly revving motor or cruising around but when I race as soon as it get in the 6000 neighborhood, she bounces around like MAD! 3,000-7000, 1000, 7000 5000etc etc very rapidly. anyone have this problem? Should I just get an aftermarket one?
I had a car I was working on do that too. The opti pigtail was rattling around causing the tach to jump all over. Check it over carefully.
A loose tach wire can do the same thing comming out of the PCM. Red connector, white wire, pin 13.
Thanks guys ill make sure to check those possibilities out, ill prolly still get an aftermarket tach just for the shift light (I have manual valve body) but Id still like the stock one to work right!
