"brake" light wont turn off..help!! ok so today i left my house and pushed down the brakes a little at a stop light cuz they werent warmed up yet and i heard a click and the "brake" light turned on like as if i had the park brake on. does anyone know how to turn this light off? its driving me nuts! thanks! |
check the fluid levels in the resevoir and make sure the switch on the handbrake is working correctly. |
If you heard a click I would be looking for a broken switch on the pedal |
the switch on the pedal can very easily come out of its hole, happened to me on my 94, easy to fix once you find it, you should be able to see how it works up under there....good luck |
Originally Posted by Lt1FBoDy209 ok so today i left my house and pushed down the brakes a little at a stop light cuz they werent warmed up yet and i heard a click and the "brake" light turned on like as if i had the park brake on. does anyone know how to turn this light off? its driving me nuts! thanks! just play with your hand brake, im sure it is the switch in there. give the hand brake a few good pushes down |
the hand brake works fine.. the light turned on after something clicked on the brake pedal. |
Originally Posted by Lt1FBoDy209 the hand brake works fine.. the light turned on after something clicked on the brake pedal. Im not sure, but im preety sure the "Brake" light will only come on due to the handbrake, the ABS light will come on if there is a problem with the ABS. Im not sure, but this is what i think. Goodluck. |
| All times are GMT -5. The time now is 07:52 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
