LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   General Maintenance & Repairs (https://ls1tech.com/forums/general-maintenance-repairs-102/)
-   -   Car won't start (https://ls1tech.com/forums/general-maintenance-repairs/340624-car-wont-start.html)
ExtinctBird Jun 22, 2005 10:14 AM
Car won't start
This issue first happened about a week ago, just after a highway drive on a hot day. A few minutes after arriving, I went to start the car and it would not crank. I thought it might be a bit of battery drain (meter read ~10V), since I had the stereo and AC cranking in the heat. After an hour, I went back out to see if I could jump start it, and it turned over on its own. No problems then for about a week.
Now, I went out to start it after it sat for a couple days, and it won't start at all. I can't jump it, and the battery is charged. All the dash warning lights seem to go through their normal start sequence, and the Service Engine light does not stay on. I hear the fuel pump running, but it does not crank at all.
What do I need to do to find the cause? Is this a starter, opti, or PCM issue?
Thanks for any help. This is on a 95 Formula with bolt-ons and pcmforless.
contraststriker Jun 22, 2005 10:31 AM
Check the starter selenoid, make sure it still has a good connection. Also check the PCM IGN fuse. It could feasably be the opti...in which case that sucks.
FlamingChicken Jun 22, 2005 11:27 PM
also check the battery cables. i know in my formula every once in awhile the negative cable gets a little loose and the car wont start but the accessories are still able to run. make sure they are all tight and then work your way back to the starter.
© 2026 MH Sub I, LLC dba Internet Brands
