Motor Mount location
Can someone direct me to where to find motor mounts on 2001 ws6. And what do I look for if the mounts need replacing?
Thanks
As far as replacing them, if your motor torques up like crazy (i.e. moves around a whole lot under throttle) then you can replace em with poly if you want. Or if you're crazy you can do like me and go with solid motor mounts.
nate
