View Poll Results: What is the best plug wire for a cam only 346?
MSD 8.8 wires
61
40.94%
Taylor 10.4 wires
42
28.19%
Factory wires
39
26.17%
Or what ever u can afford?
7
4.70%
Voters: 149. You may not vote on this poll
What plug wires are you having good luck with?
#45
Originally Posted by 86 IROC
I have had: factory wires - (obviously), MSD's, and now GMPP wires. And the GMPP wires are by far the best. They lock onto the plug and coil pack far better than any other wire I have used. That was my main gripe w/ the MSD's... I never could tell if they were on the plugs good enough. I found myself constantly rechecking them.
Bill
#48
Magnecore's. As for the plug, have had great success with Autolite 103's (.041 gap & old racer's choice for plugs). Recently have gone to E3's (non-adjustable gap) which are also dong a great job. BTW, the 103's were one temperature range cooler as are the E3's (head/cam).
#49
[QUOTE=STREET GOD]
The point being made is that plugs & wires can restore the power capability of the motor. By themselves, plugs & wires do not add power. So, what happened was you restored power that had been lost with your previous set of plugs & wires. Probably drove a little better on that day also as many variables contribute to ET's. Changing your plugs & wires was a great choice & you benefitted from it.
Originally Posted by calongo_SS
lol, you gotta be kidding me. unless you're car was missing like crazy before, plugs and wires aren't going to make a difference on these cars.
I have the time slips to prove it.
#50
I had Taylor Thundervolts on mine and was really happy with them until I tried to do a plug swap. Three of the eight came apart, even though I was careful to grab them by the boot and twist/pull. I went back to a set of OEM plug wires and haven't looked back.
-Mike
-Mike
#52
That's for labeling the wires, there should be 8 small white numbers that come with it as well. Place the "little blue stick" on the wire and push the number onto the wire.
There really isnt't a point other than to keep the wires straight. They are interchangable anyway.
#53
I have had good luck out of my MSD wires. I bought them cheap off of a 5.3 truck owner who was trading the truck in for a vette. The only problems I am having with the MSD's is when I take them off and put them back on. It is hard to tell if I have them on the plugs good. Also I have to be careful not to let them rest on the headers. If I were buying new wires I might looking into some type of wires that would not melt on the headers. As soon as I put the MSD's on I could tell that they smoothed the idle and I am getting a little better milage.
#56
The MSD's have to be pushed VERY hard onto the plug, and you have to literally "feel" the slight *click* that it gives once its on the plug. Make sure you push hard enough to get a solid seal. I didn't the first time and I threw an error of multiple cylinder misfire. After your install if the car doesn't sound or feel right, turn it off immediatly and check your wires.
#59
My car has 5 MSD wires and 3 stockers. I've always talked about replacing them so they're all the same but I always find something else to spend the money on but they seem to be working pretty well so far. I think that just about any wire should be fine on these engines.
