Sponsored by: CARiD
Electrical Problems
Old Aug 14, 2005 | 10:29 PM
tylerdj's Avatar
Exclamation Electrical Problems
I just got a 99 Z28 yesterday morning. Well the first thing I notice is that the power locks dont work. And whenever you start the car, the headlights and gauge lights will be on, without being turned on. Whenever the car is running w/ the lights on all of the lights on the car kinda flicker (headlights interior lights, turn signals, etc).
Also my dome light and map lights dont come on at all. I'm thinking this is all related but have no clue where to start looking?
I need all the help I can get! Thanks guys
Old Aug 15, 2005 | 01:10 AM
ACW's Avatar
ACW
Those are controlled by the BCM (Body Control Module), iirc. It's located behind the glove compartment.
Old Aug 15, 2005 | 05:33 PM
tylerdj's Avatar
What can you do to correct the problem? Can you do anything to that module?
Old Aug 16, 2005 | 12:35 AM
ACW's Avatar
ACW
The most likely cause is probably a loose/damaged/shorting wire somewhere; apparently the BCM needing to be replaced is much less common than having wiring problems.
The lights flickering when they're all on is probably mostly unrelated to your other issues; many people have problems with that, which can be stopped with a more powerful replacement alternator.
Old Aug 16, 2005 | 12:14 PM
tylerdj's Avatar
The lights pretty much stopped flickering. The guy I bought it from put the wires under the window so when it rolled down it cut into the wires and I think they crossed and shorted out the BCM.
