Chassis Lubrication? What is this and how is it done? What is used. I remember specifically every 6000 on my dads truck before i started changing the oil it would say on the receipt Chasis Lubrication. Every 6000 it squeaked like crazy before and then they took it in and it was fine. Will i have to worry about this w/ the T/A? How effective is this and what causes this squeaking over bumps, in tight turns sudden stopping etc. in his Trailblazer and will it happen to my Bird? What can be done to prevent this if it can happen? Tahnks Adam |
There isn't any, unless you have some aftermarket stuff. |
There are steering parts that need lubrication/grease. I think theres 2 or three greasable parts. Just use a grease gun and pump some grease into them. |
Where though? I just wanna kno incase this happens to my car. it dont seem like it would but jsut incase |
I don't know about your set up...some (like Honda) have sealed/permanently lubricated joints. My truck has ball joints and tie rod ends that have grease fittings on them...upper and lower ball joints for each side...two tie rod ends--one for left,one for right. |
Originally Posted by Pewterpowre There isn't any, unless you have some aftermarket stuff. |
Not sure how far back the years go, but on a 2002, there aren't any greasable fittings. Oh, sure you can go up there and start spraying crap with WD-40, if it will make you feel better :lol: but there are no zurk fittings on factory suspension. |
Oh alright, Thanks fellas appreciate it! I didn't think there was anyreason for our cars, but i felt i needed to be sure. |
my manual says to grease the door hinges and hood hinges every so often with something. |
© 2024 MH Sub I, LLC dba Internet Brands
