LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   General Maintenance & Repairs (https://ls1tech.com/forums/general-maintenance-repairs-102/)
-   -   Tick when A/C's on (https://ls1tech.com/forums/general-maintenance-repairs/392158-tick-when-cs.html)
Trev_SS Oct 8, 2005 11:53 PM
Tick when A/C's on
I keep hearing this freaking ticketing at a constant speed that just want seem to go away, i noticed that when i turn my a/c to the off it goes away i think that it might be coming from somewhere in the blower for the a/c. wondering if anyone has had this similar problem just drives me nuts.
thanks
2001NBMZ28 Oct 9, 2005 11:15 AM
If it does it with just the fan on too you very well could have something in the blower box - I had small leaves in mine once. It's easy to check, remove the passenger side panel under the dash, unhook the wire harness to the motor, remove 3 or 4? screws that hold the motor in and it pulls right out.
Pewterpower Oct 9, 2005 10:16 PM
Or your compressor is going. Lift the front end, get under there, and listen for it.
© 2026 MH Sub I, LLC dba Internet Brands
