ABS, BRAKE, and TRAC CONTROL lights after washing engine bay
what did i do
got a 2000 TA and yesturday when i went to wash it and decided to spray down the engine bay, well once i left the dang ABS, BRAKE LIGHT, AND TRAC CONTROL lights all stay on all the time, but other then that the car runs fine, i cant figure out what i could have done.
Did you drop a wheel off a curb, or do a huge burnout as you were leaving somewhere (like the car wash) these can trigger the brake abs tcs light
Mine did it (thought I f*cked up something major), next day it was gone and hasn't come back. If it goes away don't worry about it
Old thread, but I think I have an answer.... You got water into the PCM..or a loose PCM connection. Disconnect the PCM, let it dry, and put it back together firmly. Be carefull torquing the PCM bolts, they strip out easily.
