Problem: Driver's side window... I have not yet taken apart to see what's goinig on inside but everytime I raise my window when it is all the way down I get a rather large "BANG" from inside the door. This only happens when the window is all the way down. The window seems to track normally. Thanks, stan. |
Probably a regulator problem. You may have to replace it. Its a bitch to do though. Try removing the interior door panel and lubing the hell out of all the movable parts on the regulator with white lithium grease. Put the grease across the whole track that it slides on. My window made popping noises all the time until I lubed it. Now its very quiet. |
Thanks! :drive: |
| All times are GMT -5. The time now is 12:53 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
