Sponsored by: CARiD
RPMs going up?? weird
Old Nov 17, 2005 | 10:56 PM
MyWS6's Avatar
Default RPMs going up?? weird
Not sure if this is the right topic to put my problem in, but it's a problem nonetheless.
Car: WS6 M6
The problem concerns my RPMs going higher with my foot off the gas pedal.
I'm exiting the freeway, push the car into neutral, my speed is going down, and my RPMs keep going higher (while in neutral with the foot off the gas pedal and going up very slight incline). This continued to occur throughout my drive through city streets. It always happened right when i threw the car into neutral.
I know this happens when downshifting, but i rarely do it.
So question: Why are my RPMs going up when in neutra and my foot off the gas pedal?
Sorry if the problem isn't stated clear, i've had a long day.
Thanks in advance
Old Nov 17, 2005 | 11:33 PM
Black_Bird's Avatar
i'm sure this isnt it, but it sounds like your cruise control is on.............
Old Nov 18, 2005 | 06:43 AM
chad2775's Avatar
Mine does the same thing, from what I have heard it's not a problem. I was told that the when you take the load of the engine like that immediatetly (when its been at mid/higher rpm's) it will search for an idle. Dont know if that is true or not but I wouldnt worry about it, everyone I have talked to says its normal.
Old Nov 21, 2005 | 11:15 PM
98cobraklrws6's Avatar
i had to clean out my throttle body it seemed to work for me fine but all manuals do rev a little when you put it in neutral right away but most of mine went away after i cleaned it
Old Nov 21, 2005 | 11:17 PM
i forgot mine also did it when my intake lid was not sealed correctly check where it meets the mass air flow sensor
