Drained radiator, now won't quit dripping.
Well, I had to drain and refill with more antifreeze due to it was going to get below 0 and It was good for 15 degrees (in the garage but still gets cold). So, i opened the valve to drain some and then refill with antifreeze and now it wont quit dripping.
I have a pencil shoved in there for now. Do I have to buy a new radiator or is there an aftermarket part I can get.. Anyone know? Thanks
is it dripping from the valve on the bottom of the radiator or somewhere else. I have found that I need pliers to tighten it enough not to leak. Be gentle though as with this cold weather and that plastic its easy to snap it off. If its still leaking I would think that a sealant could be used like silicone or other waterproof sealant.
Should be fine for now. Was just wondering if they made a replacement part (as I did not look at it) to fix that..
It's likely the little O ring that is twisted or broken. I've had this happen. You can take the old O ring and buy one to replace it, or just order a new piece from the dealer.
