locked my keys in my car
Just wanted to see if it was safe to use a slim jim on our cars....the locksmith is coming in a little while...charging me $50.00 for 30 seconds worth of work...any other suggestions??
thnx
thnx
I had one used on my Trans Am and it worked fine ... wouldn't wnat just anyone trying it though without knowing it wouldn't pull loose any wiring connectors. Go online real quick and see if you can find a diagram of where everything in the door is located and you should be able to tell if it's safe to do without hosing anything up.
thnx
thnx
Ben you dumb ***.. ..just go to any GM dealer and get a key made..they can do it from your VIN number...since you moved to Mississippi you sure got stupid all of a sudden..
Yes, have a key made from any GM dealer. If would be advisable to call that locksmith, if you do go with the key from a dealer, as I'm sure the locksmith will still charge you if he comes and doesn't unlock your car.
Have you locked the keys in the car?
>If you lock your keys in the car and the spare keys are home, call someone
>at home on your cell phone and ask them to get your car keys.
>Hold your cell phone about a foot from your car door and have the other
>person at home press the unlock button on your keys while holding it near
>the phone on their end.
>Your car will unlock. It will save someone from having to drive your keys
>to you. Distance is no object. ;You could be hundreds of miles away, and
>if you can reach someone who has the "remote" for your car, you will be
>able to unlock the doors (or the trunk this way!)
>Editor's Note* It works fine! We tried it out and it unlocked our car over
>a cell phone each time we tried it.
>Have a nice day!
>Have a nice day!
Originally Posted by sdbrown84
Someone at work sent that to me. I have had some people try it and it works. Give that a try.
Originally Posted by OOZ28
Umm do you have t-tops? If so you can pull the passenger side window out just enough to reach your arm in and unlatch it, take it off, and unlock the door.
Edit: I wonder if the whole cell phone/remote thing works?
occasionally people will suggest this trying to see how many people will go for it...he most likely copied it from a forwarded email, notice the >'s....and you know how reliable those are...
edit: here's the snopes article...verifying it's false...
http://www.snopes.com/autos/techno/keyless.asp
in the article they say what i said about the radio vs audible waves...
Originally Posted by silver02ss
wow...didn't know it was that easy to get in the car. i'm going to have to try that...and then lock my tops, so someone else can just open the car. the alarm would go off, but still they wouldn't even have to break anything.
Yeah, Ive gotten into my car many times just pull the window. If It helps you can use a some oil(cooking) or somthing and your arm will slide right in. I swear there is so many ways to get into a Fbody its not even funny.
