Something's wrong!! Feels like the car is coming apart!!
Somethings wrong!!! Feels like the car is coming apart!!
When the car gets to a high RPM i am getting a real bad shaking vibration. coming from under the car I can feel it through the shifter a lot and its sort of a dull blunt rattling vibration but very stong. Very bad when you leving firts gear really getting on it and also leaving 3rd I have also noticed that the clutch is giving out because it does kinda the slow-mo high reving but your not relly going anywhere thing ha ha! when say your leaving second going into third. Car has 85,000 on original clutch mods in sig.
Have you gotten under the car to check everything out? Sounds like your torque arm is loose. Check where it mounts to the transmission and to the rearend and make sure those bolts are tightened up real good.
Dont know if it will help, but my car was doing that type of thing. Turned out my pilot bearing had turned into a fine dust. Did a number on the input shaft and shredded the shims in the tranny. nasty.
