Oil pick up tube part number?
Old 01-29-2006, 01:29 PM
99whitews6's Avatar
Default Oil pick up tube part number?
What is the GM part number for the oil pick up tube on a 99 LS1 trans am?
Old 01-30-2006, 02:35 AM
ACW
ACW's Avatar
LS1 F-body oil pump pickup: 12558251
Old 01-30-2006, 04:59 AM
99whitews6's Avatar
Hey thanks, I have another post below in which I am looking for the part number for the crankshaft key. Know that one??
Thanks again!
Old 01-31-2006, 03:10 AM
ACW
ACW's Avatar
In your other posts you said you're looking for lifter tray, dowel pins, and crankshaft key for a 6.0L. The majority of what I have is for 5.7, and I'm not having any luck at trying to find those from alternate sources, sorry. If you wanted regular 5.7 LS1 numbers (don't know if they'd be the same as 6.0), I could probably find those.
Edit: But then I see in your PM that you just want an LS1 key?? If so, this should be it:
LS1 crankshaft balancer key (length 37.5mm, width 4.77mm) = 12561513
And WhiteRhino just posted the corrected lifter tray number in https://ls1tech.com/forums/generation-iii-internal-engine/445440-ls2-lifter-tray-retainer-part-number.html --
LS2 valve pushrod cover guide (lifter tray) = 12595365
