Front driver-side turn signal bulb burnt out
Old 01-29-2006, 06:30 PM
91s10LS1's Avatar
Default Help??? Bulb Burnt Out Its The Driver Turnsignal Light Up Front
Does Any One Know How To Change The Bulb ON the driver side . it s the marker light the one for the turn signal. its sounds easyer than it is!
oh yea its a 2000 SS Camaro
Old 01-29-2006, 06:34 PM
ss rally red's Avatar
Pull out the headlight assembly,1 10mm bolt, slide assm. sideways and it will come out,very easy to get to the bulb your talking about.
Old 01-29-2006, 06:39 PM
91s10LS1's Avatar
THANKS THATS WHAT I THOUGHT BUT SOMEONE TOLD ME U COULD REACH IT BUT I GUESS THEY WERE WRONG
Old 01-29-2006, 07:03 PM
NC98Z's Avatar
You can reach it. Access is thru bottom trapdoor panel bolts are also 10mm. You just can't see what your doing but the wire leads are long enough to reach where you can see to change bulb. But I believe i'll try the remove the lite way next time.
Old 01-29-2006, 07:06 PM
It depends if you want to lay down to change it or stand up to change it
Old 01-29-2006, 08:24 PM
SgtB's Avatar
lay on the floor for all of 4 minutes and change it through the trap door
Old 01-29-2006, 09:52 PM
blkZ28spt's Avatar
I took the headlight out. I tried reaching through that stupid door but there was oxidation and the old bulb took more force to remove than I could apply through my extremely vicarious position/grip when reaching through from the bottom.
Old 01-29-2006, 11:17 PM
Ell Ess Won's Avatar
ok....and what do you need help with again?
Old 03-17-2006, 05:16 PM
GoldenBird's Avatar
That one 10mm at the top right? I slide sideways but no dice. I don't want to exert too much pressure in fear of snapping something. You're not supposed to have to undo any other bolts to get at it?
Old 03-17-2006, 05:58 PM
GoldenBird's Avatar
Aaargh....yeah the trap door is Useless with a capital "U" on a Y3F equipped car.
Old 03-17-2006, 08:34 PM
RoastEmSS's Avatar
took me about 5 mins going through the trap door
Old 03-22-2006, 02:02 PM
lo_jack's Avatar
I swapped the bolts on the trapdoor access panels to face downward and be held on with wingnuts...mmmm convenient.
