Help Pinion Seal Leaks
Old 02-09-2006, 06:47 PM
Ronnie Abene's Avatar
Default Help Pinion Seal Leaks
HELP I went from 323 gears to 373 gears went to the track made four passes a few days later I noticed pinion seal leaking. I changed the seal went back to the track it started leaking again Then I went to 410 gears and I changed the seal again went to the track now its leaking again. Anybody know anything about this. Please pm me or email me at bigred122@charter.net. THANKS
Old 02-16-2006, 07:26 PM
Pewter02's Avatar
This seems to be a pretty common problem. I've already had mine replaced twice on my '02 (7,000 & 25,000 miles) and it's still leaking. I had the pinion seal replaced 4 times on '98 in a 50,000 mile span. As long as it's not bad enough where it drips onto the ground, I'm not too worried about.
Old 02-16-2006, 08:01 PM
MYTFASTSS's Avatar
three words..........
"Get a Girdle"!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 02-18-2006, 12:52 PM
ernie22golf's Avatar
Where can you get a girdle and how much should one cost.
Thanks
Old 02-19-2006, 05:30 AM
MYTFASTSS's Avatar
Anyone of the Fine Sponsors to the right should have one, I like Thunder racing Myself. I was having my rearend serviced twice a year for Pinion seal leakage. Neighbor told me to get a "Girdle" w/ stud kit and I won't have this problem again. Sure enough, it's dry as a bone back there. Never have looked back....
I believe a Girdle is the Best Upgrade to the 10 bolt.
It usually will run ya about $160 or so. Want the Stud kit, add another $15 or so to that price. It's well worth it. I got the TA Girdle.
