turn signal bulb Doe's anyone know the bulb number for the rear turn signal lamp?like you could pickup at autozone/advance.2002 camaro ss. |
yeah i need this info too heh |
3157LL is the long life bulb at autozone all your bulbs are going to be a wedge type all dual element bulbs example turn signal and running life = 3157 all single element will be a 3156 hope this helps. |
Just so this info is out there....They are 27watt/8watt bulbs. I spent the time looking and so far I find no reason why a 1157 bulb and matching harness will not work for a bad harness. |
Originally Posted by Twister Just so this info is out there....They are 27watt/8watt bulbs. I spent the time looking and so far I find no reason why a 1157 bulb and matching harness will not work for a bad harness. |
1157 is what i use. Some places still carry them...or versions of them at least. |
Originally Posted by waiting2bl33d 1157 and 1156 are just older versions of 3157 and 3156 new technology = wedge style your pre 96 automobiles for the most part are 11XX bulbs and 97+ are the 31XX |
© 2024 MH Sub I, LLC dba Internet Brands
