LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   General Maintenance & Repairs (https://ls1tech.com/forums/general-maintenance-repairs-102/)
-   -   What's your oil filter? (https://ls1tech.com/forums/general-maintenance-repairs/457101-whats-your-oil-filter.html)
93ChevExt5.7 Feb 20, 2006 05:29 PM
Hi,
Who uses what oil filter with your LS1? Pennzoil, K&N - what part numbers?
Thnx
Patman Feb 20, 2006 06:21 PM
I use the K&N HP1007
davered00ss Feb 20, 2006 06:46 PM
Nappa gold
GreekGator Feb 21, 2006 12:42 AM
WIX filter
T-rex Feb 21, 2006 12:50 AM
K & N 2006.
Swedez28 Feb 21, 2006 07:09 AM
I have used anything from Fram (I know they are supposed to suck) to Bosch, Delco, K&N, Mobile 1. I wont be using Fram anymore cause of all the negative comments here. I have recently picked up 3 AC delco filters on sale so I am good for a while. I also kinda like the Bosch. Seems to be built well. I change my oil often so I cant see the 10-12 bucks for K&N. My advice is to just stay away from the cheap junk.
Mike02Z Feb 21, 2006 07:36 AM
I've always used the K&N HP1007. I decided to switch to the K&N HP2006. Can anyone tell me if I will have any clearence problems with the larger filter?
Thanks.
waiting2bl33d Feb 21, 2006 09:07 AM
im using the larger mobil filter M1-206 (i think) and i have no clearence problems at all install univisity says the LS1 takes 5.5 qt w/ filter and since it is bad to overfill i figured i'd go w/ the filter that makes it closer to 6 full qt.
Judge Smales Feb 21, 2006 12:39 PM
So is it safe to say that if we use the bigger K&N filter that we can put in a full 6 quarts?
radkon Feb 21, 2006 12:57 PM
Ditto, haven't been able to find the 2006 anywhere local.
The Guz Feb 21, 2006 01:17 PM
AC Delco here.
GreekGator Feb 21, 2006 03:15 PM
where do you guys buy the delco filter and how much are they?
T-rex Feb 21, 2006 07:51 PM
Advance Auto Parts. The nut on the end hangs down below the pan a little.[On the hp 2006 that is.].If you hit something hard enough to to hit the bottom of the filter,you have other stuff to worry about. :)
Mr Yak Feb 21, 2006 08:33 PM
Mobile 1 oil and oil filter, they fucked me over at my own dealership. I was thinking, lets keep some money internally maybe $30 max. fucking $62 later I got my keys. I will never get my oil changed here again.
RDISADEIFAN Feb 22, 2006 08:47 AM
AC DELCO PF 59 here
Muerte_X Feb 22, 2006 08:51 AM
Supertech (wal-mart brand), it's like 2 bucks and I've been using them forever and never had a problem with them.
I forget the part number, but the numbers match up with Fram and the others.
orangeapeel Feb 22, 2006 10:38 AM
Fram, gotta love the grip.
stinkfinger Feb 22, 2006 09:19 PM
what vehicle takes the larger filter that we can use? (so I can look up parts #'s)
c4hybrid2007 Feb 23, 2006 10:28 AM
Well guys i just so happen to work at Autozone(this means i am no expert by the way :) ) and we cut open all of the filters we sell to do a comparison. I can tell you this as far as low end filters are concerned the STP filter is the better quality over Fram, and even the Fram Tough Guard it is also cheaper. As far as middle end filters go AC Delco, Bosch, and Motorcraft are alll about the same. The Bosch is a surprisingly well amde filter and i wouldnt hesitate to use one. The top filters K and N and Mobil 1. With Mobil 1 being the champion here. I know i would at Autozone so ill have my flame suit on here but this is just what i noticed.
JakeY2KZ Feb 23, 2006 11:17 AM
Yes I use the 2006 and use all 6 quarts just fine. I've actually read where guys were using 6 1/2 quarts with the longer K&N.
© 2026 MH Sub I, LLC dba Internet Brands
