car is lock i can't get i no door key
i just tuned my car about 3 week ago and my battery died out do i have to get the car retuned
thanks
thanks
go find a cavalier, has to be one within 50 feet...unscrew the antenna, may take 8mm wrench...Slide it thru window, even if it's closed it will sneak in...hit unlock button and BAM, you're in...
Go get your grandparents or any other family members blood pressure machine. Then slide it inbetween the window seal and the window. Blow up the balloon on the pressure sleeve to the max and slide a hanger in and pick the lock....Worked on an eclipse for me...
English is a second language isn't it?
A locksmith could def. get you in, but they are expensive and have a tendency to break things... I've done it w/ a dipstick from an Explorer before (emergency)..anything long and skinny should work! Good luck!
The other day I had the t tops off and the window down and didn't have the keys on me (I was just in the driveway) but I had locked the car and when I pressed the unlock button it would not work. But the lock button still worked. It might just be my car but it might be a safty feature gm put in for when u leave the t-tops off. Someone correct me if Im wrong. Might have just been my car.
the guy that put the electrical system together in these cars must have been drunk, or a retard
