Sponsored by: CARiD
Trunk latch isn't opening right
Old Mar 3, 2006 | 07:05 PM
pHEnomIC's Avatar
Default Trunk latch isn't opening right
I am having trunk latch problems. IT is weird. I know the keyfob takes two pushes to get the trunk to pop. Well, now, It makes me hit is twice for the trunk to pop up just a little bit. Then i have to push it again twice while giving upwards force on the spoiler or hatch. It gets to be a problem when other people have to open the trunk or the car is running and you want to pop it. (Turns into a two person job, one to hit button, one to push upwards.)
Anyone ever have this problem and how did you fix it?
Old Mar 3, 2006 | 07:11 PM
hondo's Avatar
www.installuniversity.com has an article on how to fix it, I think you add a spring to the latch. My car does it too,pretty common. I need to fix it soon.
Old Mar 3, 2006 | 08:30 PM
9silverbird8's Avatar
piggyback a 2 1/2 inch long 5/8 spring onto the factory spring on the latch mechanism....problem solved.
Old Mar 3, 2006 | 10:00 PM
pHEnomIC's Avatar
Sweet, I was thinking about doing that myself, nice to know what size works though so I dont have to trial and error.
Old Mar 4, 2006 | 12:31 PM
pHEnomIC's Avatar
That took a total of 2 secs to fix, Thx guys. Just unscred the bump stops a bit and it works perfect.
Old Mar 5, 2006 | 09:41 AM
davered00ss's Avatar
Moderator
Yup, what he said.
Old Mar 5, 2006 | 03:49 PM
Danny2tek's Avatar
works like a champ
Old Mar 5, 2006 | 03:54 PM
prostock_bigblock's Avatar
have exactly same problem and I was pissed when i am alone . sprayed WD40 and worked great.
Old Mar 5, 2006 | 03:57 PM
StangEaterSS's Avatar
i just piggy backed that exact spring on mine, still didn't fix it. it pops up like 1" or so and falls back down. wonder if the struts on the hatch are go'n bad? maybe they are too weak.
Old Mar 6, 2006 | 12:15 AM
2002_Z28_Six_Speed's Avatar
Greased mine with wheel bearing grease and now it works normally.
Old Mar 9, 2006 | 06:58 PM
Steve74-02's Avatar
just added a spring to mine. now it works great. thanks
