Tube that comes off the airbox
Old 03-07-2006, 06:01 PM
ravensfan's Avatar
Default Tube that comes off the airbox
What function does the tube that comes off the airbox have? You know the one where if you install a lid you have to put a breather filter on? Thanks
Old 03-07-2006, 06:20 PM
2001NBMZ28's Avatar
It provides air to the cats on startup while the air pump is running.
Old 03-07-2006, 06:43 PM
ravensfan's Avatar
And if there is no air being sucked in, what kinda symptoms would that cause?
Old 03-07-2006, 06:47 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Nothing at all. You can remove the air pump.
Old 03-07-2006, 07:21 PM
ravensfan's Avatar
well the car is having trouble idling at start up...It stumbles down to around 300 rpms, then levels out.....Then when I give it some gas, the revs come down, but instead of holding around 800-1000, then drop down below 500, and the car almost stalls out......
Im scheduling a tune up soon, but its driving me nuts not being able to figure this out
Old 03-07-2006, 09:44 PM
ZeeVert's Avatar
I'm no expert, but there could be some issues with just removing the air pump. At the very least there may be some other "adjustments" to make. I found this thread:
https://ls1tech.com/forums/showthrea...light=air+pump
