recharging air conditioning system?
I have been told that now moisture has entered into the dryer and it needs to be replaced.
I've also been told that the sys. needs to be connected to a cleaning machice before I even think about recharging the sys.
Thanks for any recommendations
or you can pay for professional service, in which they would swap dryer and evacuate the system (vacuum) and then charge it with new 134a.
done the home garage empty and fill a few times and have never had a problem. even without putting a vacuum on the system, also its a hell of a lot cheaper to do it yourself.
hopefully you have a haines manual cuz that help.
pm me if you need anymore assistance.
P.S. if you dont change the dryer just means you might have a shorter compressor longevity. i would recommend changing the dryer, but i wouldnt worry about cleaning the system. or if your concerned charge it with a can then run it for a few minutes then bleed off the system, then recharge it again.
