LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   General Maintenance & Repairs (https://ls1tech.com/forums/general-maintenance-repairs-102/)
-   -   car won't start (https://ls1tech.com/forums/general-maintenance-repairs/480458-car-wont-start.html)
478TAM6 Apr 1, 2006 09:58 AM
car wont start
igot home last night just getting my car out of the shop and right before i got home i nailed it one time to see if it was runnin good because i havent drove it in like three months and as soon as i pulled up in the drive way it shut off and then i tried to crank it when i turned the key on it started a loud clickin noise and and wouldnt turn over a all and soon as i turned the key off the gauges went crazy going up and down, im wonderin if its and ground or my ecu or solenoid or what any comments will help.
Black Z/28 Apr 1, 2006 05:12 PM
Sounds like it's probably your battery.
Z28LS1camaroguy Apr 1, 2006 07:11 PM
same shit that i went through, got in the car one day and barely started, so i drive to work and once i get there i shut her off and get ready to head in then i was just thinking i wonder if she will start. sure enough try to start the car and damn clicking and the engine wont turn over and start, turned out to be the battery and replaced the old one with a new Optima battery and starts without hesitation now. damn good batterys and very reliable, left my car sitting for two weeks when i went to louisiana and came home started right up middle of winter also.
JoeZLS1 Apr 12, 2006 01:57 PM
I had the same exact problem. Definitely the battery. Clean the cables. Make sure the battery is charged and connected tightly. Batteries tend to last as long as they are intended. So if your 3 or 4 or 5 years isn't up yet then your cables probably just need to be cleaned.
BlackBirdWs6Zzz Apr 13, 2006 05:32 PM
I think you need a new battery too. Or it could just be that your cables to the battery aren't tight enough. It will make that clicking it it's touching but not really screwed on!
jay_99z Apr 13, 2006 05:41 PM
Sounds like battery/battery cable for sure. What did you have done at the shop?
Nice4thgenZ Apr 13, 2006 05:54 PM
yup check the cables, but sounds like the battery
© 2026 MH Sub I, LLC dba Internet Brands
