Sponsored by: CARiD
Normal idle
Old Jun 4, 2006 | 11:08 PM
blackbirdls1's Avatar
Default Normal idle
What is the idle suppose to be at on a 2001 Stock LS1 ?
Old Jun 4, 2006 | 11:26 PM
staringback05's Avatar
about 500 rpms...mines a shade under that but i just got a 01 motor put in my car so its trying to learn....umm in my old 99 motor...it was at 500 and it was smooth
Old Jun 4, 2006 | 11:36 PM
ok good mine is very little above the 500, could just be inaccurate but the idle is fine, not rough at all was just curious
Old Jun 5, 2006 | 02:28 AM
GET_SOM's Avatar
most TAs idle at 750...
Old Jun 5, 2006 | 01:05 PM
2001NBMZ28's Avatar
Car warm, in gear, foot on brake my tach showed just over 500 (fluctuating 525-585 on a scanner). In P/N fluctuated 645-676).
Old Jun 5, 2006 | 02:12 PM
jmm98LS1's Avatar
Stock warm idle settings on an ls1 a4 car is 650rpm in park/neutral and 550 in gear.
Old Jun 8, 2006 | 07:17 PM
GXPPOWER's Avatar
Default ..
mine idles at 500 or alittle under once its gets warm
Old Jun 8, 2006 | 09:35 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
This is correct. All years of LS1s have the following stock idle settings:
A4: 550rpm in gear, 650rpm park/neutral
M6: 800rpm
The stock tach is not 100% accurate, on a scanner my A4 will be showing an idle of ~550 in gear, but the tach shows more like 650-750rpm. Then I shift to park and it jumps to 650 on the scanner, but more like 750-850rpm on the tach.....
Old Jun 9, 2006 | 05:43 PM
Sunset'01Z's Avatar
sometimes i'm running at like ~500 in gear at a light.. i'm thinking a tune up could help? i got some ngk plugs and wires ordered, probably going to be installing them next week. will that help increase my idle and smooth it out?
Old Jun 9, 2006 | 06:47 PM
it depends, ngks tend to mellow out but its also up to your wires and tune
