Sponsored by: CARiD
Hatch Problem
Old Jun 13, 2006 | 04:57 AM
old and good's Avatar
Default Hatch Problem
hi it seems the hatch on my new TA is fitted oddly the hatch seems to be further back than the rear fenders... it so far back that when i close the hatch it hits the breaklights and the panel in beetween them slightly so i cant even close the hatch properly. is there a solution to this.. can i adjust the rear hatch like i can with the hood?
Old Jun 13, 2006 | 05:03 AM
427-WS6-87-02's Avatar
Can you post pictures?
Old Jun 13, 2006 | 05:12 AM
ill try to post them tonight it just seems like the entire hatch is to far back. i know the car had a slight accident before i bought it but the sail panel seems to be in the right place and the t-tops fit fine so i cant understand why the hatch dosnt firt corectly.. i culd the hatch wuld need to go back about a quarter of an inch or maybe a bit less so that it wuld look right
Old Jun 13, 2006 | 07:41 AM
victimizati0n's Avatar
probably hit from the back, and something is messed up there, but didnt affect the ttops
Old Jun 13, 2006 | 08:15 AM
that cannot be becouse everything is alligned correctly exept the rear hatch. if the car had been hit from behind the rear bumper or something else wuld not allign with the fenders i guess
Old Jun 13, 2006 | 10:58 AM
Low N Slow's Avatar
There is some adjustment on the hinge bolts, the hatch is heavy so make sure you have help if you loosen the bolts.
Old Jun 14, 2006 | 03:26 AM
Well hi guys! i think i found the problem, it seems like the roof (or just the back part of it) is a bit to low that culd wery well be as a tree fell down on the car and hit the top and must have bended the roof. im going to take a look at the adjustment thing on the hinges and try to fix that.. or else ill have to see a shop to correct the roofpanel
