Trip meter resets it self and gaugres go crazy
When im at the track and i do my burn out the trip meter will reset its self...have no clue why but it does......Also befor when i went to move my car i started it up and the gauges where going crazycar was surging also fuel gague was floping all over. checked all my grounds thro the car and wires on the starter are all fine im clue less
Not to suggest it again, cause its aready been said, but I had a similar prob. Got the battery tested, checked and all. Ended up having to get it towed cause it wouldnt run. It would start, but unless I stayed in the throttle, it would die right away. Turned out, it was the battery. It was in my truck, but hey it can happen. Those things can cause some crazy probs. Buddy of mine has a 97Z, he went to lock his doors one time and it kicked his CD out of the player. It was the battery. WIERD. Good Luck
my battery basically blew up today... it was leaking everywhere and steaming and ****, obviously the car dided right before this happened. is that my battery or is it something else?
I had the same thing happen in mine.
It was the battery.
It was completely shot, leaking fluid everywhere. If you do have fluid in your engine bay, wash that **** off asap and then pour some coke on it...I did'nt and got some rust.
It was the battery.
