LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   General Maintenance & Repairs (https://ls1tech.com/forums/general-maintenance-repairs-102/)
-   -   oil on the spark plug thread Pic's (https://ls1tech.com/forums/general-maintenance-repairs/571238-oil-spark-plug-thread-pics.html)
dopy Sep 6, 2006 02:47 AM
yes I did a search. I didn't find the answer I wanted.
I did a spark plug change and found oil on the spark plug threads only on cylinder #7. This is the second time Ive changed the spark plugs and oil was there the other time (4000miles ago). I would like to know if it is my PCV valve causing it?
https://i26.photobucket.com/albums/c...24-2006061.jpg
https://i26.photobucket.com/albums/c...24-2006063.jpg
and this is a pic of the intake
https://i26.photobucket.com/albums/c...Picture090.jpg
https://i26.photobucket.com/albums/c...Picture087.jpg
so is this enough oil it get oil on the spark plug threads?
I do not consume oil at all and if I do its not noticeable
Thank You
Joe
98LS-WON Sep 6, 2006 11:24 AM
Those look like good plugs to me. A little bit of black is fine as long as it isn't still wet.
dopy Sep 10, 2006 01:15 AM
that's what I thought.
I'm just trying to find the cause of my KR at 4100-4800RPMs and Its gone by 5000RPMs. I think Ill try some top end cleaner
thanks
RPM WS6 Sep 10, 2006 11:24 AM
I get some oil on the plug threads too on #7 and I think #2 as well. I've never really given it much thought because there is never any oil on the electrode or anywhere on the tip of the plug, just on the threads.
Also, my motor consumes 0 amount of oil. It does get oil in the intake through the PCV but I don't let that concern me as it's not enough to cause any noticeable consumption issues.
taintedmeat Sep 10, 2006 03:17 PM
That's how my plugs looked too, I wouldn't sweat it.
Cool pics of the inside of your intake :)
dopy Sep 12, 2006 12:23 AM
thanks good words
qwik_ss Sep 13, 2006 12:58 AM
Yeah they look to be in ok condition
reocamaro Oct 4, 2006 03:12 PM
I have the same problem, and I'm just curious how it is "ok" that oil is on our spark plugs. Is there any rationalized reason behind this?
RPM WS6 Oct 4, 2006 08:13 PM
Well I look at it like this,
- No oil to be found on the electrode, only minor amounts on the threads of 2 or 3 cylinders.
- My motor consumes no measureable amount of oil between changes.
- I have no misfire conditions.
- Motor runs/idles fine.
So I guess you could say that it's not so much that it's "ok" to find this condition, but since I don't see any ill side effects after many years, it's just not worth worrying about.
staringback05 Oct 4, 2006 10:10 PM
intake actually looks pretty clean
© 2026 MH Sub I, LLC dba Internet Brands
