Passenger side carpet wet after rain storms
It rained, my windows were up, and this isn't the first time... the carpet on my passenger side floor board is soaked. It's not leaking through the t-tops and dripping down, it's coming from somewhere else. I don't even know where to begin looking!
The same thing happened to me. With mine it was the passenger side rubber grommet wasn't on all the way since I had to put a power wire from my amp in my trunk to the battery and in the process I hadn't replaced the grommet totally. I would look there first.
I just had one on my driver side. It cam in through the inside of the weatherstrip all the way from the top of the t top channel and soaked my whole driveside front and back. Im trying to get it done under GM warrenty, im about a year out of it but still in my aftermarket warranty
Could be the missing grommet in the firewall. Just checked it out. Did you just get another grommet and run the wires through there again? Pretty sure that'd be a huge pain. I'm thinking there has to be an easier way.
I'll fix that and see if I can find any other leaks too.
