Start grinding????
Start grinding????
I just got my car back from the body shop and Now my car is having a hell of a time tryign to start. When i go to turn the car over it makes a grinding noise and and keeps grinding. It does this a few times and then it finally catches and the car turns over. Do you guys think it is my starter missing teeth or the flexplate that has teeth missing?I
I would jack the car up and drop the inspection cover over the convertor/flexplate. I would use a pry bar or something similar and move the flexplate and inspect to see if the teeth are in tact. If so, it is the starter.
Its sounds like the starter to me, but I would check the flexplate to make sure.
