right rear blinker/brake
Old 09-25-2006, 01:45 PM
KJKJ's Avatar
Default right rear blinker/brake
I have a 01 formula, the other day my passenger side rear turn signle/brake light quit working. But the tail light works just fine. I tried new bulbs and still have the same problem. Anybody else ever have this problem or any ideas as to what it might be??? Thanks in Advance.
KJ
Old 09-25-2006, 01:58 PM
SoCalZ28's Avatar
check fuses
Old 09-25-2006, 02:51 PM
KJKJ's Avatar
have not found a bad fuse
Old 09-26-2006, 06:30 AM
WannaZ28's Avatar
correct me if im wrong:if you turn on the night lights, the rear lights work, but when you hit the brakes, they dont work. i had the same problem, and it was due to a bad ground in the socket itself. if youve ever cut a bunch of wiring and spliced them with another part, this job takes less than 5 minutes. include a decent set of shrink tubing.
if you go to a GM dealer, they will charge you 60 bucks ONLY for the socket PART. I went to autozone, and got a similar socket, cost me 5 bucks, make sure it is the flat kind because our car's lights are shallow (youll see what i mean).
