Car throwing Codes - 135 & 155... What are they?
My car randomly started throwing codes this morning. It hasn't been sitting in direct heat nor in extreme cold. It's throwin 2 codes of 155 (Bank 2 Sensor 1 Malfunction), and 1 code of 135 (Bank 1 Sensor 1 Malfunction). Can someone direct me to a website to look these exact codes up or point me in the right direction of a repair or what the cause may be?
Yeah I've had problems with my 02 sensors before and they just randomly stop throwing the code. Will this most likely happen? Why does it randomly throw the code and then randomly stop?
Its the sensor heaters. Like you said yesterday was a fairly cold day here and first of the year, maybe that is it. If so its only gonna get worse. You moght try the Vette Boschs, or upgrade one see if it gets rid off on of the codes and if it does replace both. Since youve got the longtubes and the sensor is further away from the stream, it would cure insufficient switching too (if youve ever gotten it)
Sensed Parameter
(B2S1) HEATED
OXYGEN SENSOR
HEATER CIRCUIT
Fault Code
P0155
Descriiption
Detects a malfunctioning
HO2S heater circuit by
comparing time to HO2S
activity to a calibrated
threshold.
Malfunction Criteria and Threshold Values
Oxygen sensor time to activity
exceeds a lookup table value as a
function of average flow rate.
Secondary Parameters and Enable Conditions
Cold Start (IAT & ECT <50 C and less than 8
degrees difference)
Valid mid bias calculated
18 v > System Voltage >10 v.
No AIR, EGR, Catalyst diagnostic active
No Throttle, MAT, Camel Mode, Injector, EST
Control, Coolant, Crank Sensor, Knock Sensor or
Air Flow Faults active
Once per cold start trip.
MIL Illumination Type
B
(B2S1) HEATED
OXYGEN SENSOR
HEATER CIRCUIT
Fault Code
P0155
Descriiption
threshold.
degrees difference)
B
You've already got your solution above, you're getting heater circuit malfunction codes from your front o2's. This is very common with longtubes because the sensor is further downstream in the exhaust, compounded by the fact that steel tubes don't retain heat as well as cast iron manifolds and the sensor just can't stay hot (cooler weather will also compound the problem). Your options are to ignore the codes (even turn the ses light off for that code w/tuning software) or upgrade to bosch 13111 (rear C5 sensors) that have a stronger heat circuit. The cheapest I've found the 13111's is $69 from autozone.....I just replaced mine last week.
Yeah I saw that jimm and I appreciate your help. But Like I said the light turned off from driving about 20 miles. So therefore it's not throwing the code anymore.
