check wheels Sensors ? ABS/TCS off
Well it happened here Also,,, That Dang ABS inop Light and the TCS light are on i was driving about 45 had to stomp the breaks,,, LA drivers.. back end went sideways and the lights came on.. im thinking i need rear pads due the the rear end slide and that noise is getting louder !! squeeek!.. but from what i read i might have a wheel sensor out. any one have a sure fire way to check,,, also will needing pads do this ?
I am not sure how you could test a wheel sensor. They all seem to have infinite resistance when checked.
Sounds like you have some serious brake problems; which is why you went sideways. The difference in one side locked up and the other still spinning set off the ABS/TCS as a secondard effect and probably didn't help.
Hope you didn't wreck.
Check out those brake pads. Make sure all lines are bleed properly and nothing is leaking.
