another ls1 camaro cranks but no start question
Hi, i just got a 98 ss 6 speed camaro i purchaesd with 47k delieverd from Arizona Yesterday. the car fired right up off the transport. I shut off ..started up a few minutes later..drove up driveway about 900 feet. Shut off... restarted 10 minutes later and drove to in laws house (3 miles). left in laws with wife driving car drove home 3 miles....car stalls in our drive way( yes she had clutch in yes full tank gas ) would not restart ...just cranks and cranks. waited about 1/2 hour tried again no start.. just cranks .. i can hear fuel pump turn on for a couple seconds. today i checked spark while cranking with timing light...it shows spark that way. Hooked up fuel pressure guage ...swithched key on/off several times ... no fuel pressure...thought guage bad??? Pushed in shrader valve no fuel. Changed fuel filter...no pressure.... tried different key ...(vatts?) no start just cranks?? Bought a $150 code scanner... no codes...
questions..... if a vatts problem would car crank and have spark and fuel pump on ??? Ill need to get a noid light for injectors i guess??
In the short time i drove i noticed the coolant light was on in dash ?? but coolant level is ok in the radiator?? can this be part of it??
Researching in old posts re coolant temp sensors ..if this is problem would i still get spark with pump running but no pressure??
Crank positions sensor?? if bad would i be getting spark???
Engine ran strong for the 7 miles i drove it!! feels to have adequate compression when cranking.
can fuel pump be bad even though it makes what sound to me to "sound normal"(i have had several efi gm vehicles ..fairly sure pump "sounds" ok)
car had a dealer installed gm alarm(similar to stock alarm option) i armed and disarmed this thing every which way... i would think alarm wiould not alow to crank??
Owner says he never had issue with not starting( original owner ..very nice seems very honest)
I checked all fuses ...i read a couple posts regarding ign relay swap with starter relay ...but i am seeing spark ( at least inducted spark from my timing light) wiil try that..
ANY SUGGESTIONS ??? wife wants to castrate me for buying as it is... now with this problem shes even more pissed!!
Thanks
Thanks
