Squealing Idler pulley?
I suspect I may have overtorqued the idler pulley and caused the dust cover to rub the bearing somewhere. Can I just take the dust cover off? Which side is the dust cover the inside or outside or both? Could I remove one or the other or both or neither ?
Any other ideas would be appreciated.
Also if you got an idler pulley from autozone, napa, or kragen, you may not have to use the dust covers. Most of them don't require you to use them because they have sealed bearings. That's what I read on the instructions, but I chose to install them anyway.
Buuut, it fixed the problem!! The car is silent, ... well except for the exhuast
Damned Idler pulley.
Chirp all gone.
