Car won't start even after VATS bypass
I've had the VATS bypassed for a year now, and the other night all of a sudden the car won't start. It won't even crank, the starter won't engage even. The voltmeter (on the dash) doesn't even register any voltage on it with the key in the on position. Any idea what this is???? Possibly a fuse?
No the headlights and dome lights come on fine so its got power, even with jumper cables. Which wire is it going to the starter that may cause it to behave like this?
Thanks for your help guys. I finally figured out it was the fuse label "Gauges" that was not making good connection. Apparently there is some connection between this and the ground on the relay (located under the hood) for the starter. Works good now thanks.
